Sponsored by:
Sponsored by:
Will 285/40/18 fit up front?
Old 06-28-2006, 05:54 PM
UrS4
UrS4's Avatar
Default Will 285/40/18 fit up front?
I would like to know if I can put a 18 x 10 rim up front and out back (replica older saleens) with 285/40/18 tires all the way around. The wheel offset is 45mm and the tires will keep the correct tire diameter.
Will these tire fit in the front without modification like spacers etc. My car is still at stock suspension so will it clear? I know the saleens run 275 all the way around so will these tires work?
thanks guys
UrS4 is offline
Old 06-28-2006, 08:37 PM
UrS4
UrS4's Avatar
Default RE: Will 285/40/18 fit up front?
nobody knows???
UrS4 is offline
Old 06-28-2006, 10:20 PM
blackv6
blackv6's Avatar
i heard no... i plan on getting 18 x 8.5 and 18 x 9.5 with a 35mm offset all the way around, and that will only fir with one specific wheel design. 45 all around is what i believe most go in the rear to fit the wider tire.
blackv6 is offline
Old 06-28-2006, 10:29 PM
RICVA05
RICVA05's Avatar
Here you go https://mustangforums.com/m_644549/m.../tm.htm#644549
RICVA05 is offline
Tivo304
08-28-2023 12:19 PM
guitarman376
10-11-2015 01:47 AM
Oak
09-14-2015 03:08 PM
Sparks_88
09-08-2015 01:06 PM
09-01-2015 08:16 PM
Quick Reply: Will 285/40/18 fit up front?
