noisy transmission
noisy transmission
is it normal for the transmission to make clanking and clunking sounds when shifting? it genereally only does it at lower speeds, i drive my car pretty hard and i dont remember if it was there or not before lol, i hardly ever drive slow enough to be able to hear it either way... just askin is it normal
RE: noisy transmission
ORIGINAL: Kaldar142
ORIGINAL: Kaldar142
nope driving the same way i always drive, the car just hit 5k miles today so i doubt anything is wrong with the clutch lol
Or it could just be the linkage...
I think you are just hearing driveline slack. To take the clutch out of the picture, drive along about 20mph and give it a lot of gas/let off/give it gas again. Is this the same clunk that you are referring to? I think these rearends have a lot of backlash set on the ring and pinion. Mine is quite clunky (along with transmission whine and grinding going into 2nd gear) that basically the same drivetrain in my 2001 has nad does not do. It does clunk some though.
