disable retained power accessory?
Old Jul 30, 2006 | 01:39 AM
Skoshi42's Avatar
Skoshi42
Default RE: disable retained power accessory?
Just remove the plug for the map lights, thats what I did... as for the acc delay, the only other thing is to wire your stereo to a power source that shuts down when the key is out of the ignition... i think that is your only option..
Old Jul 30, 2006 | 04:21 AM
Treatz's Avatar
Treatz
ORIGINAL: 06GT4RAD
I always turn everything off before i shut the car off anyway so no big deal. Why not simply do the same.
Richard
i'm going to have to get into the habit of that
the only downside is the car deck will stay connected to my phone via Bluetooth, so the BT connection won't drop until i'm a good distance away
Old Aug 3, 2006 | 01:50 PM
Treatz's Avatar
Treatz
ok, so in GT manual fuse 44 is for "retained accessory"
i'm gonna try and pull that fuse. It says it's a mini fuse.
The manual is'nt very specific though, where is the panel? i assume it's the one under the hood by the washer fluid.
Old Aug 3, 2006 | 02:40 PM
bl1nk's Avatar
bl1nk
There is also one in the passenger side kick panel
Old Aug 3, 2006 | 02:54 PM
Treatz's Avatar
Treatz
hmm ok,
any idea where fuse 44 would be?
NVM: answered my own question:
power dist box is located under the hood
ORIGINAL: bl1nkage
Old Aug 3, 2006 | 03:13 PM
Treatz's Avatar
Treatz
ok that didn't work.
i pulled fuse 44 and the radio and power windows didn't work at all.
hmmmmm
Old Aug 3, 2006 | 03:55 PM
bl1nk's Avatar
bl1nk
Have you checked the manual for how to disable it? I could have sworn I read somewhere where it told you how.. If I had mine with me now Id look but Im at work sorry.
Old Aug 4, 2010 | 03:49 PM
Treatz's Avatar
Treatz
BUMP:
has anyone found a solution for disabling the retained power accessory?
other then wiring my radio to the ignition vs acc, i'd like a simpler solution
Old Aug 4, 2010 | 05:27 PM
doode's Avatar
doode
Originally Posted by Treatz
BUMP:
I had to resort to that
snipped the power wire from the radio harness and hooked it straight to ignition
jwog666
Dec 27, 2021 08:09 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
