GRANATELLI COLD AIR KIT
#21
RE: GRANATELLI COLD AIR KIT
ORIGINAL: siggy14
How much was that? and who did you order from? I wonder if one of the board sponsers sells them.
http://www.lethalperformance.com/pag...d-filters.html
Just did some tracking though Fedex, it should be here tommarrow[sm=wootwoot.gif]
#23
I found it for $305.00 and right now we get 5% off for forum members.
http://dagostinoracing.com/index.php...ducts_id=11498
#24
The key with the tune is the increased size of the MAF sensor tube. The MAF sees less air coming across it when the same amount of air is entering the engine (smaller tube=higher velocity) but maybe more restriction (stock). The aftermarket CAIs that require a tune have larger diameter tubes to mount the MAF sensor in, though they do allow better airflow, they still read less than stock, and therfore need a tune. The reason the K&N setup and I might guess one of the optional Granatelli setups might not need a tune is that they maintain the stock MAF tube diameter. It is not that the cars computer cannot respond to the changes, it gives the warning lights and goes into safe mode because the information it recieves from the MAF is way out of perameters for the way the engine is running...
Hope some of this helps on the tunig part.
Skrappy
Skrappy
09-01-2015 08:16 PM
