Door panels
Old Aug 11, 2006 | 01:29 AM
videtto's Avatar
videtto
Default Door panels
Hi, I'm new to the forum. I hope I'm in the right area. Anyway, I was wondering if anyone has removed the door panels on an 05 or 06 mustang. I tried to remove mine but I couldn't. I removed about 15 screws including a hidden one behind the door pull and the panel was very loose but something was still holding it on. Just wondering if there is a trick to it or something else.
Thanks for any suggestions.
Old Aug 11, 2006 | 01:59 AM
svt93style's Avatar
svt93style
Default RE: Door panels
ORIGINAL: videtto
Well I can't speak from experience on an 05-06 but I have done this several times on a foxbody mustang....there are these plastic "screws" so to speak that have jagged edges on them that push into holes in the door, you either get a specal to to pop them out or you can just pull them out with a little force...either way you have to buy new ones when putting the door panel back on...actually you can reuse them a few times but then the ridges start to give...sorry this isn't to descriptive but it is hard to explain...
Old Aug 11, 2006 | 02:20 AM
bchoice's Avatar
bchoice
Pull off the window switch panel and find another hidden screw! Remove that one and you are good to go.
Old Aug 11, 2006 | 02:49 AM
svt93style's Avatar
svt93style
ORIGINAL: bchoice
I stand corrected, they have update the door panel design.
Old Aug 11, 2006 | 05:13 AM
05HOTROD's Avatar
05HOTROD
are you changing out your inside door handles?
Old Aug 11, 2006 | 05:22 AM
GTlust's Avatar
GTlust
I ♥ Acer
Before I waste my time can anyone tell me if the insert around the armrest (part that is a dark grey on my car) seperates from the rest of the panel? I noticed on the two tone interiors it is a different color and I want to tweed mine blue to match the exterior.
Old Aug 11, 2006 | 09:25 AM
videtto's Avatar
videtto
Thanks for the info. Actually, I'm trying to replace the factory speakers.
Old Aug 11, 2006 | 09:32 AM
fairlane292's Avatar
fairlane292
Get a pr of std radio door panels, relocate your speakers (Under dash or elsewhere) for a much cleaner look; no more kicking those nasty looking speakers. (There are better looking ones out there, at least do that) JMO.
[IMG]local://upfiles/24316/52F98563376D41408F953AD3D761F06D.jpg[/IMG]
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
jrrhd73must
Oct 2, 2015 09:17 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
