Kicker
Old Aug 17, 2006 | 02:21 PM
  #21
drbobvs's Avatar
drbobvs
Default RE: Kicker
Check Crutchfield, I recommended against getting the built in amp, b/c the controls are hidden from use once it's mounted. The separate amp will allow you better control and a wired remote if you like.
Old Aug 17, 2006 | 02:40 PM
  #22
bl1nk's Avatar
bl1nk
Default RE: Kicker
ORIGINAL: drbobvs
Thanks alot, Ill check into it. Im certainly not in a hurry so Ill have some time to do some research. I know MTX is a good name but how is that particular sub? Also is it a 12" or 10" and did you wire it in all in yourself or was it done "professionally"?
Old Aug 17, 2006 | 05:13 PM
  #23
drbobvs's Avatar
drbobvs
Default RE: Kicker
It's a 12" and I wired it myself. In my vert i found nowhere to hide the amp so i fugured i'll just flaunt it, right in the middle. Mounted a red neon light under the deck to light up the compartment too. My remote is located in the center console.
TimeLord101
Sep 4, 2015 09:27 AM
69FB
Aug 18, 2015 08:50 PM
MuscleOwnzRice
Feb 19, 2006 01:58 PM
MuscleOwnzRice
Feb 1, 2006 12:42 PM
thelast50ho
Aug 19, 2004 10:22 PM
