Squeeky Springs
Squeeky Springs
I lowered my stang with the sportline drop and a BMR adjustable panhard bar. If I adjust the rear end centered on the wheels the passenger side rear squeeks and cringes. If I adjust it just slightly (about 1/8") off center toward the driver side, the squeek lessons. Anyone know what could be causing this. I'm still riding on stock shocks but it almost sounds like a binding type thing.
RE: Squeeky Springs
Could it be sway bar or shock bushings binding? Might pay to put the car up on a rack and see if you can spot anything that looks like it's not lined up right or binding. It might help to loosen the shock mounts and sway bar end links and then torque them back down. I've seen that allow things to settle after making suspension changes. Just a thought.
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
