Pioneer 7800MP head unit installed with iPod adapter ...
I bought the entire setup from Crutchfield for $350 shipped .... that included the Head Unit, iPod Controller and all the wiring adapters and install kit. I soldered all the connections to the Crutchfield harness the other day at my kitchen table. I also installed the 5V regulator on the subwoofer power feed as recommended on this board (thanks to whoever that was.)
I had delayed the install because I thought it was gonna be a pain in th azz ... but today was overcast and a little cooler in my driveway to be working in the car. Well .. I had the old radio out in about 10 minutes .... the Crutchfield directions are top notch. Also ... since I had pre-wired everything the Crutchfield harness plugged right into the car. I used the power off the power plug in the center console to power the iPod controller which is also used the charge the iPod. I would say the entire install took about 30 minutes and I am very pleased. The amount of settings on this head unit is unbelievable and it sounds great. The 64,000 color display looks awesome. I was expecting slow response times from the iPod as I had read elsewhere on the internet ... but it seemed plenty fast to me ... Here are some pictures ...
RE: Pioneer 7800MP head unit installed with iPod adapter ...
Where did you install the 5 volt regulator? Where did you buy it and what is it's function? Does it stop the large pop when you turn on/off the radio?
Yes ... it stops the POP when you turn on the radio .... You can get it at Radio Shack for like $2 ... it gets soldered to the AUX power feed to drop the 12V coming from the stereo down to 5V ...
It is a model 7805 and looks like this ...
I have been going back and forth between the pioneer model you have and the Sony CDX-GT705DX. Both have things I like but i think i will end up with the Sony.
Plus points of the Sony is cheaper $279 (pioneer 319)
Signal to Noice ratio is better at 120DB (pioneer is 100DB)
13 band EQ
2 year warrenty.
Plus points for pioneer
Color display (not a big thing for me)
5v Preamp outputs (sony is at 4V)
From past experience i have found that the sony's radioi volume is lower then the cd volume. With my last pioneer i could adjust it to even it out, so i would assume they have it on the newer ones too.
I will probaly end up with the Sony, but who knows, i am also really into the HD radio's, but they are still not big enough of a selection. Yours looks nice, does it have the fuction where the radio station and the song from the radio station is displayed? i like that function on our stock radio's.
13 band EQ
2 year warrenty.
No ... I could find no setting to display the Radio Station info ... kinda sucks. Yes ... you can adjust the FM vs. Aux sound to keep them at the same level.
09-01-2015 08:16 PM
