HELP WITH GRILL!!
Old Sep 7, 2006 | 12:40 AM
eric.sd's Avatar
eric.sd
Default HELP WITH GRILL!!
Can some please tell me how to install this grill NO INTUCTION CAME WITH IT!
so far i got the radiator cover off and i'm trying to take the grill off but i can figure it out.
I would appreciate ant help THANKS!
Grill: http://www.mustangtuning.com/2005-mu...grille-gt.html
Old Sep 7, 2006 | 12:44 AM
backinblack06's Avatar
backinblack06
Default RE: HELP WITH GRILL!!
I could be wrong, but I don't think you take the old grille off, you just place that one over the existing honeycomb stock grille.......maybe do a search, I think there are instructions on here somewhere.
Old Sep 7, 2006 | 12:46 AM
eric.sd's Avatar
eric.sd
I have done a search with no luck... It looks like I need to take the grill of to get the dam pony off I can't tell if it has screws in the back of maybe it just pops off..
Old Sep 7, 2006 | 01:15 AM
eric.sd's Avatar
eric.sd
They have to be $hiting me I quote...
"These quality grills install in 10-15 minutes and no cutting or drilling is required!"
now look at the instruction's from the manufactures website.
http://www.grillcraft.com/installs/i...?install_id=82
Old Sep 7, 2006 | 01:27 AM
bl1nk's Avatar
bl1nk
Billet grills lay overtop of the black stock one you dont replace it. I wish they replaced it because I dont want the stock grill behind my billet, but I have looked and looked for a long time and found one that requires you to take off the stock one (but it moves the fogs to the center).. so unless that one is new then Im pretty sure it just lays over.
*corrected
Old Sep 7, 2006 | 01:38 AM
eric.sd's Avatar
eric.sd
NOT THIS ONE...not only do I have to take the stock grill off I have cut the grill to remove the pony's housing it sticks out about 3/4" with out the pony! and the billet does not sit into place. the stock grills laying in my living room as I'm trying to find my sawsaws blade.
Old Sep 7, 2006 | 01:43 AM
hammeron's Avatar
hammeron
nice choice on the grill, i am going to get the same one....
Old Sep 7, 2006 | 01:45 AM
bl1nk's Avatar
bl1nk
Right, but it still uses the stock grill to lay over top of correct? Minus the part about having to cut the pony mount off? Those directions looked like it layed over top of it like all others then you just put it back on with the billet secured to the black plastic.
Old Sep 7, 2006 | 02:22 AM
blackout's Avatar
blackout
The Cervini's you are supposed to take off the stock grill although Ford didn't for the GT-H.
I know you don't need it because you drill the Cervini's Grill into the body.
-Jeff
Old Sep 7, 2006 | 02:29 AM
SPARTAN VI's Avatar
SPARTAN VI
How about post a picture the the grille you bought. Most of these grilles just snap right on top of the stock grilles. I think we need to see it to believe it- "it" being that you have to drill and cut to get that grille in.
