Sponsored by:
Sponsored by:
Dash rattle worth a trip to the dealership?
Old 11-02-2006, 08:57 PM
05 Ricky
05 Ricky's Avatar
Default RE: Dash rattle worth a trip to the dealership?
ORIGINAL: kcary
Question, what kind of noise is that you all are having? I was reading the TSB and it doesn't sound like my issue. Mine is like a squeeking sound, almost sounds like two pieces of plastic rubbing on itself. It also sounds like it's formnt he far passenger side of the dash. Appears more on bumpy roads and doesnt appear related to speed or rpms.
Mine rattles over the same condictions as you, bumpy roads =[:@]Mine is coming from the middle of the dash about a couple of inches from the windshield. When I put pressure on it, it goes away. I took it to the dealer today so I will give a result when I get it back, they had to keep it over night because they fixed one rattle and started another[:@]
05 Ricky is offline
Old 11-02-2006, 09:54 PM
mAnYsTyLeS
mAnYsTyLeS's Avatar
Don't do it...the more you mess with your car...the more screwed up it gets. When that gets fixed...something else will rattle
mAnYsTyLeS is offline
Old 11-03-2006, 01:59 AM
HypromanGT
HypromanGT's Avatar
ORIGINAL: 05 Ricky
ORIGINAL: kcary
I have the exact same thing, only from the drivers side. This rattle started AFTER being at the dealership for the infamous water leak problem (still leaking, btw) in which they had to apparently remove part of the dash. As much as it bugs me to try to fix it myself, I am starting to think more like mAnYsTyLeS; chances are if they do fix the rattle, it will open up another one somewhere else...
HypromanGT is offline
Old 11-04-2006, 08:25 PM
05 Ricky
05 Ricky's Avatar
Just got her back and they actually fixed the rattles, we'll see how long it last's, they said all the could do it put double sided sticky tape every where till it stopped rattling. You cant see any of the tape but atleast it doesn't rattle for now.
05 Ricky is offline
Old 09-05-2009, 11:05 AM
Ghostrider4918
Ghostrider4918's Avatar
Does anyone know where I can find the TSB for the dash rattle? The dealer claims they cant recreate the problem. Also does anyone know about water leaking inside the car on the driver side?
Ghostrider4918 is offline
Old 09-05-2009, 11:28 AM
157dB
Cut & Paste Expert
157dB's Avatar
Search 'water leak' and read the tsb about the leak.....
157dB is offline
Old 09-05-2009, 04:09 PM
05 Ricky
05 Ricky's Avatar
Holy cow.......I made this thread almost 3 years ago......someone must have done some digging.........
05 Ricky is offline
alan0614
Carolina Regional Chapter
38
11-30-2015 09:24 AM
chrisdbassplayer
10-13-2015 06:53 PM
folivier
10-02-2015 05:34 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Dash rattle worth a trip to the dealership?
