Antenna options?
Old Nov 2, 2006 | 09:26 PM
Menace's Avatar
Menace
Default Antenna options?
I'm a little frustrated, and I'd like some suggestions.
I purchased a shorty antenna, and when I attempted to test fit one of the three threads (for different styled mustangs) I seemed to have found the one. So after it threaded a turn or two it got stiff... So I turned it with a wrench and it snapped... Great... So I spend $40 at Sears to get these screw out things. I try it and it doesn't work. So I got frustrated and tried drilling the rest of it out. So after drilling, picking out pieces, and whatever else... it seems I got it all out but ruined the threads.
So the question is, do I buy a whole reciever? (Cost around $17... Unfortunately it goes down the inside of the fender and through the firewall, and the only disconnect is right before it plugs into the radio. -- beneath the passenger seat.) It would be a real pain in the *** to do this. Plus you have to remove the wheel/plastic covering underneath. I've done it already just to follow the line.
Do I try to tap it out, and use the larger screw attachment for the shorty antenna? I don't exactly know how to do this, so it won't be as easy as I would think.
Or does anyone have any other ideas?
The screw out did work on the antenna itself, so it was salvagable. Sad... I know. I should have stopped when the threads weren't going in, but I guess I had an airhead moment.
jwog666
Dec 27, 2021 08:09 PM
kevsgt
Oct 9, 2015 10:12 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
marc954
Sep 29, 2015 03:05 PM
