Where is MPH Measured?
Old Nov 3, 2006 | 05:09 PM
Larmo's Avatar
Larmo
Default Where is MPH Measured?
So I'm getting new tires... fronts are going to be stock height at 255/40/18..... but I am considering 295/35/18 in the back, which is slightly shorter than stock height and thus will throw my speedo off a smidgin. My question is, since my front rubber is stock height (speedo correct) and my back rubber is a little off, will it affect my speedo? In other words, if MPH is measured at the front tires I will be fine, but if its measured at the rear tires (which I am guessing since its RWD) then my speedo will indeed be off.
Sorry if I confused you. I think I just confused myself.[:@]
Old Nov 3, 2006 | 05:12 PM
saltzy's Avatar
saltzy
Default RE: Where is MPH Measured?
Lots of modern cars are measured at the transmission, thus the back wheels on the Mustang. With speed being calibrated through the ECM, I would bet this is the case, however I don't know this for a fact on our cars.
Old Nov 3, 2006 | 05:25 PM
vsop's Avatar
vsop
Yep, your speedo will be off.. We have an electronic pickup that sends the speed of the tail shaft to the ecu. So changing rear tire height or gears throws off the speedo
Old Nov 4, 2006 | 10:15 AM
Bulitt's Avatar
Bulitt
My *** [8D]
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
TCStangerv6
Oct 11, 2015 05:57 PM
jrrhd73must
Oct 2, 2015 09:17 PM
69Volunteer
Sep 30, 2015 10:39 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
