Window Tint Dealership Resolution Update
RE: Window Tint Dealership Resolution Update
Absolutely. I plan to post an update when its out of the shop but I also want to see if the part(s) they order is a good fix so Ill keep the forum posted.
ORIGINAL: bascho
If the glass is being scratched then that is an issue for Ford to fix. If it's just the tint then Ford has no obligation to cover the cost of repair. Window tint is not 50 state legal for the driver and front passenger door anyway. In most cases you won't even have legal recourse. Have you installed the moleskin or felt yet? It's not Ford's responsibility to design the belt moldings for use with window tinting.
Again, if your glass is getting scratched then that is a different issue entirely.
- Justin
UPDATE - Just wanted to givethe foruman update on my scratched window tint problem. As I have mentioned before, my local dealer is paying to re-tint both windows. Yesterday my car went into the shop to replacethe door parts that are apprently causing this problem. They ended upreplacing the driver's sideglassbecause the scratches were so bad on that side. The passenger side was not as bad so they did not find scratches in the glass on that side. Tomorrow is my appointment to have the windows re-tinted. I hope the new parts installed in the doors will be the fix, only time will tell. Those of you with tint scratching, be cautious because you never know if more damage exists. I would have never thought the entire glass would need replacing. Good luck!!
KingRando
10-02-2015 08:06 AM
