Need Help about Dyno tuning
Old Nov 26, 2006 | 12:18 AM
Stroken97's Avatar
Stroken97
Default RE: Need Help about Dyno tuning
ORIGINAL: MSgt46270
I would at least check the A/F readings. With a good tuner you'll make more HP, but not too much with the mod that you have. The biggest thing for you is to make sure your current tune isn't running lean or too rich. Mail order tunes can always be improved with a local tuner. I once a tune that gave me 328hp and toke the car to get a better tune and my current tuner still made 354hp.
If you decide to get a new tune, flash your programmer back to stock first. DO you have SCT or Diablo? SCT you will be able to use with your new tune. With Diablo you WILL have to have Ford flash the PCM back to stock.
I have a Diablo at it saves the stock tune so I don't understand why someone with a Diabol would have to have Ford reflash the PCM?
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Sixx
Oct 5, 2015 07:36 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
