Painting headlight housings
I saw it done on a roush and it looks great. Take the glass off and paint the black the color of your car. I am goign to do this with my redfire. I am looking at getting a set of used lights and go from there. I have the paint and just need to find the headlights now. What would be involved. Sanding to rough the old surface. Adhesine promoter (which I never have good luck with, always lays higher in some areas and paint doesn't really stick to it), paint, clear and seal the headlights back up. Has anyone done it yet?
RE: Painting headlight housings
Good luck with it. There have been many a destroyed headlights from people attempting this. There used to be someone advertising doing it on TMS and he was charging like $300 or so plus paint, plus your headlights. The "take the glass off" part is what is going to kill ya. Only recommendation I have is bake it at low temp, use a damn sharp razor knife, and take your time. Because remember, once you do finally get it to come off, you are going to have to be able to not only put it back together, but also seal it to keep moisture out.
I'd leave 'em be too, for 3 reasons.
1) They look the best the way they are, no matter the color of your car. I've seen them painted and I'm not impressed.
2) Chances are nil you can remove the lenses and paint them and have them look like you didn't do it yourself.
3) Chances are less than nil that you can ever put them back together and have them stay watertight.
ORIGINAL: TElke1
sounds like a mess! I would just leave them alone!!
Good Luck!
i've done it very easy too. check it out!
[IMG]local://upfiles/55755/20432DD5EDD243BBA5D9D191AF68353A.jpg[/IMG]
[IMG]local://upfiles/55755/4A6B076D04AD491FB206BB2966C94861.jpg[/IMG]
[IMG]local://upfiles/55755/E13957CF713C445A807392EA48F42371.jpg[/IMG]
[IMG]local://upfiles/55755/A67FBBE3F1574899A26B95A5FBC872CB.jpg[/IMG]
mungodrums
09-28-2015 10:54 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
