Automatic Transmission question
Old Dec 2, 2006 | 12:13 AM
Skoshi42's Avatar
Skoshi42
Default RE: Automatic Transmission question
I have this delay as well.... like my engine will rev up then reverse will kick in.... this only happens when im doing quick D to R or R to D shifts.... I made it a habait to always come to a complete stop to shift .... problem fixed...
Old Dec 2, 2006 | 12:17 AM
Rupp's Avatar
Rupp
ORIGINAL: Skoshi42
But is yours 2-3 seconds? I'm patient enough to wait but it seems excessively long.
Old Dec 2, 2006 | 12:49 AM
Skoshi42's Avatar
Skoshi42
Yes, it is 2 seconds at the most... if I step on the gas during the gear change, it will spin the tires.. I will buy a tuner to up the shift pressure... this should correct the problem...
Old Dec 2, 2006 | 01:06 AM
bl1nk's Avatar
bl1nk
Skoshi, how do you change things like that (shift pressure)? I have the SCT and when I look through it to change things, there like 10, maybe 12 different parameters and theyre the basic things like speedometer limit etc.. I cant figure out how to find the more complex stuff.
Old Dec 2, 2006 | 02:12 AM
2k05gt's Avatar
2k05gt
ORIGINAL: daliab
I have a 2006 GT - 6 months. No problems. You might want to check the auto trans fluid level.
This is somewhat odd but How do you Check or Change the Fluid in the auto trans????
I can't find a DipStick anywhere.
Old Dec 2, 2006 | 09:25 PM
Rupp's Avatar
Rupp
ORIGINAL: 2k05gt
ORIGINAL: daliab
See post #4
Old Dec 2, 2006 | 09:26 PM
06GT4RAD's Avatar
06GT4RAD
ORIGINAL: 2k05gt
ORIGINAL: daliab
The car has to be put on a lift and it has to be checked. It has a special plug with a plug inside the plug essentially. No dipstick.
Richard
Old Dec 3, 2006 | 03:16 AM
DoctorQ's Avatar
DoctorQ
ORIGINAL: Archion
That would be the machanical parking pawl disengaging, you must be parking on some kind of incline in either direction, it is normal, but if you want to avoid it use the e-brake
ORIGINAL: DoctorQ
I've got a 2006GT auto... no delay engaging; however I do get a semi-loud metallic clunk when shifting in/out of Park
This happens in my garage...perfectly level, and I always use the e-brake....
Old Dec 3, 2006 | 05:23 AM
paulsoo217's Avatar
paulsoo217
I don't have that problem on my 06 gt. But i have a problem with some hissing sound as i accelerate when O.D. is off especially when car is cold. Anyone has it too?
Old Dec 3, 2006 | 06:45 PM
daliab's Avatar
daliab
Sorry 2k05gt... I ment to say you should have the fluid level check.
