Need major help!!!
Old Dec 17, 2006 | 02:13 AM
Apoptosis's Avatar
Apoptosis
poptart tits
Default RE: Need major help!!!
ORIGINAL: Arwing
ORIGINAL: KTownGT
Lol, Anoxia, if that is your real name,
I got the article, sorry mods for posting the other forums [&o]
http://forums.stangnet.com/showthread.php?t=661846
lol thats my cs name
thanks for the link
1.6 or source?
No problem.
Old Dec 17, 2006 | 02:14 AM
Arwing's Avatar
Arwing
source
Old Dec 17, 2006 | 03:08 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Great advice I love this website and the and the knowledge or (lack there of)! It great to see people help[sm=americanasmiley.gif][sm=groupwave.gif]ing out with a common interest our stangs
Old Dec 17, 2006 | 12:43 PM
edified's Avatar
edified
Ktowngt is correct. Forgot to tell the dealer not to download ford's updates? You can tell them not to for they will never tell you if they would. Good luck!
Old Dec 17, 2006 | 01:11 PM
rex7010's Avatar
rex7010
I play that game also.. in a Guild called the 907th.. you should be able to find use with the info I just gave you..
R
ORIGINAL: Arwing
source
Old Dec 17, 2006 | 02:32 PM
Newbreedgt05's Avatar
Newbreedgt05
I'd be willing to bet that it is the fuel pump. Especially if you sprayed brake cleaner into the throttle body and it started. It's just not getting any gas. If it was something with the computer, then it wouldn't have started with the brake cleaner. It might not be a coincidence that the fuel pump decided to go out at that same time either. The instructions for the tuner say that you should remove the fuel pump fuse before you put the tune in the car. Some say that's just to keep the fuel pump from running when the tune is installed , but maybe in your case the fuse blew out. I would check the fuse and replace it. If that doesn't work, maybe have the fuel pump replaced. It's definitely a problem with the fuel delivery system though.
Rich
Old Dec 17, 2006 | 04:16 PM
HypromanGT's Avatar
HypromanGT
ORIGINAL: Newbreedgt05
Rich
+1
When I read the initial post I immediately thought "no fuel delivery". I was going to suggest fuel shutoff switch, but then there would be no reason for that to trip from back of the lot to front of the lot. Considering the instructions for loading the tunes, the fuse idea is probably dead on!
Old Dec 17, 2006 | 06:00 PM
07AlloyGT's Avatar
07AlloyGT
i'm betting on the dealer changing the cars code. the sct just kinda screwed it up when you tried to reflash.
Old Dec 17, 2006 | 08:27 PM
BlackBetty's Avatar
BlackBetty
I've got the SCT with the canned SCT tunes, and i just took my car in for the parking brake TSB. I flashed to stock before taking the car in. Since the generic SCT tuner can be used on multiple cars, will it cause this same problem if I try to retune when I get the car back?
Old Dec 18, 2006 | 09:53 PM
Arwing's Avatar
Arwing
Finally got the car back, im afraid to tune it again though
im just gonna call brenspeed tomorrow...
