car dead
Old Dec 22, 2006 | 10:42 AM
skillful's Avatar
skillful
Default car dead
Came back into town and my car was dead. (nothing works at all) Dont have a clue as to how it happened. Would it be as simple as hooking up jumper cables and starting it or do I need to call ford and ask questions. Wasnt sure with it being a new car. Any suggestions?? Thanks
Old Dec 22, 2006 | 11:14 AM
6xStang's Avatar
6xStang
Default RE: car dead
mine croaked after sitting for 22 days. Dead as a doornail.
I jumped it (it needed to charge for a while before starting with my cheapo cables), and all is fine. I will try to remember to turn off Shaker before shutting car off in the future.
Car ran a little funky for the first few hours as the PCM RAM relearned the engine parameters (I think).
Old Dec 22, 2006 | 08:06 PM
madmike's Avatar
madmike
+1 on making sure the "skipper" is off!
Old Dec 22, 2006 | 08:35 PM
Rupp's Avatar
Rupp
What does "make sure the radio is off before shutting the car off" do? Mine goes off as soon as the door is opened. Are you guys pulling a Dukes of Hazard and jumping through the windows?
Old Dec 22, 2006 | 08:38 PM
07AlloyGT's Avatar
07AlloyGT
ORIGINAL: Rupp
What does make sure the radio is off before shutting the car off? Mine goes off as soon as the door is opened. Are you guys pulling a Dukes of Hazard and jumping through the windows?
you have to actually push the volume **** in to turn off the radio. if not then the amps still receive flea power enough to drain the battery after sitting for a period of time. generally it's like 2 weeks.
Old Dec 23, 2006 | 12:14 AM
rex7010's Avatar
rex7010
Ever since I have done the radio trick.. mine has started right up now every time..
crossing fingers for next time.. but the " radio trick" ( turning it off after you are done driving...does work ) did
on mine..
R
Old Dec 23, 2006 | 12:33 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Many threads on this and it is true! get a battery tender plus and hook your battery to it if you are gone extended periods of time and it will start when you return
Old Dec 23, 2006 | 01:13 AM
Caution's Avatar
Caution
Never heard of the radio thing but I guess I better start doing it -- I dont want my car to die
Jskeezy84
Sep 8, 2015 01:40 AM
microgt
Aug 20, 2015 07:12 AM
jjwinel78
Aug 17, 2015 03:34 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
