is this normal?
Old Dec 27, 2006 | 09:40 AM
GT2006am's Avatar
GT2006am
Default RE: is this normal?
Didn't see your post and just posted my own (titled Hood Jump) describing much the same thing. I think I'm going to see what the dealer says. Starts at 65 and up around 100 it's far worse. You would think that the air over the hood would keep it pinned down - but it seems like the air-flow under the hood is almost greater at speed?
Alan
Old Dec 27, 2006 | 10:47 AM
fairlane292's Avatar
fairlane292
Yeah, let us know what the dealer says.
Thanks.
Old Dec 27, 2006 | 11:34 AM
stangster06's Avatar
stangster06
I ♥ Acer
fairlane - thanks for input on this. Can you please expalin what rtv silicone is and how you used it to test contact?
Sounds like GT2006am tried to adjust them with some success. Another suggestion was adjusting the latch/catch. I would think the dealer needs to do this.
GT2006am - I am very curious about what the dealer says/does - please let us know if you take it in.
Thanks
Old Dec 27, 2006 | 12:07 PM
2oo5stang's Avatar
2oo5stang
wow, i would definitely take it in and see what they say. I know if you get an aftermarket hood, hood pins are the answer. i've seen to many times, happened to a friend too, where they put aftermarket hoods on and popped up hit the windshield. My 95 GT, had the Cobra R ram air hood and i was driving it and it popped up like i pulled the latch so i quickly pulled over and pushed it back down, when i got home i ordered hood pins and it never happend again.
Good luck with it and dealing with Ford to hopefully fix it
Old Dec 27, 2006 | 02:00 PM
fairlane292
RTV high temperature silicone comes in a tube at any local auto parts store.(comes in several colors: red, black, blue, grey, etc) Using as a marking film is just an easy way to see if contact is being made, in this case between the 4 rubber stops and the hood. Get a color that is distinctive from your car color, spread a thin film across the top of the rubber stop, shut the hood, open and see if any of the silicone is on the hood. From what you see on the hood you can tell what kind of contact is being made. Easy to cleanup, wipe away and run several tests until you are happy with the results.
Old Dec 27, 2006 | 02:05 PM
wcgman's Avatar
wcgman
Fairlane has the right idea but instead of running to the parts store I used an old carpenters trick. I stole an old tube of lipstick from my wife and used that. I was able to adjust the stops easily after that. I had to adjust mine because I installed the hood struts which then required me to slightly adjust and realign the hood.
Old Dec 27, 2006 | 02:39 PM
fairlane292
I did that once and she left me (lol), so now I have RTV on hand :-)
Old Dec 27, 2006 | 04:54 PM
stangster06
I ♥ Acer
Thanks for the help guys. The lipstick sounds good but I'll also look into the silicone. This sounds like a good test to do before taking to the dealer. Regards.
Old Dec 27, 2006 | 06:12 PM
fairlane292
Yeah, this is a simple test and you want to knowfirsthand, if these stops are properly adjusted anyway. ...before talking to the dealer.
I am paranoid about a service rep shutting my hood. Some people still push down on hoods to shut them. I can ill afford a "dented" custom painted hood; even if it is their fault. When I go in for my first service there will be a sign on my dash "DO NOT PUSH DOWN ON HOOD TO CLOSE" If they are insulted that's too bad. To shut mine I simply drop from about 12" up and it shuts nicely. (If I loosened the stops so they don't contact I could drop from about 4-5" to close) ...this might give you an idea how tight mine is. As I indicated a brief cruise up to 105 for a bit, then back down showed no signs of movement in the hood. I don't have a track around here to race and don't run those speeds on the streets anyway, but it's good to know the thing is snug.
Old Dec 27, 2006 | 08:34 PM
xbone's Avatar
xbone
How come hood pins are not the solution? Hood aint comin off with pins! I dont think this is a defect, its justa big lightweight hood. Mustangs have always had this problem, why do you think Shelby put pins on them back in 66?
