Drive Shaft Replacement
Old Dec 29, 2006 | 03:01 PM
Sherwood06GT's Avatar
Sherwood06GT
Default Drive Shaft Replacement
I'm looking for recommendations on drive shaft replacement. What kind, where to get it, etc. Is it hard to install? What are the benefits and for those of you who have done it, does it make a noticeable difference? Please chime in with your thoughts and ideas.
Old Dec 29, 2006 | 03:11 PM
clearym's Avatar
clearym
Default RE: Drive Shaft Replacement
From what I can gather, this is not something you want to attempt yourself. Apparently the balancing and/or shimming issue is very tempermental. You don't want that thing vibrating and if done right you'll eleminate enough rotating mass to get about 10 extra RWHP. I'm probably going with a one piece aluminum in the springtime. You should be able to get one of those for $650 on LM or american muscle and then find a quality installer.
Old Dec 29, 2006 | 04:02 PM
jay0heavenly's Avatar
jay0heavenly
there's a couple of posts about the driveshaft. You can either go aluminum for around 700 or carbon fiber for close to a grand. Both will get you about 10hp to the wheels but the Carbon fiber one reduces the noise and vibration better, hence the extra 2-3 hundred. A lot of guys on the forum have done the install themselves, but if you have done any suspension work, you're gonna need an adjustable LCA or something to correct your pinion angle.
The aluminum one is made by powerhouse and the carbon one is made by BMR... have fun.
Old Dec 29, 2006 | 04:05 PM
Sherwood06GT
ORIGINAL: jay0heavenly
Yea, thanks to both. I really like the BMR carbon fiber shaft. Think I'll go with that one and have it professionally done. LMPerformance will be the one.
Old Dec 29, 2006 | 04:44 PM
CrazyAl's Avatar
CrazyAl
The driveshaft is very easy to install!!
All the balancing is done at the factory. When you get the driveshaft, you just bolt it on, reset your pinion angle,and go. It takes about 30 min. There is no shimming.
Old Dec 29, 2006 | 04:52 PM
Riven02's Avatar
Riven02
+1 Driveshafts are CAI easy.
Old Dec 29, 2006 | 05:18 PM
jay0heavenly
ORIGINAL: Riven02
Thats what I'm talking about!!!! If they are CAI easy, then there aint no way in the world I'm gonna pay to get it done!
Old Dec 29, 2006 | 05:23 PM
moosestang's Avatar
moosestang
I wouldn't say CAI easy. There's no lying on your back with a CAI and you don't need a torque wrenchfor a CAI install. Adjusting and measuring the pinion angle can be a daunting task.
ORIGINAL: Riven02
djbigskrilla
Sep 20, 2022 01:04 AM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
mirandaandjimmy
Nov 16, 2015 08:51 AM
Urambo Tauro
Sep 7, 2015 12:47 PM
kevans79@yahoo.com
Aug 18, 2015 09:01 PM
