ZEX wiring
Old Jan 6, 2007 | 11:24 PM
airbillster's Avatar
airbillster
Default ZEX wiring
Installed my ZEX kit today with the remote bottle opener, almost, I want to run the electrics through the console and in the glove box but don't see an easy way to remove the dash or console to run the wires under. Does anyone have a how to on this?
Thanks in advance!
Old Jan 7, 2007 | 01:50 PM
airbillster
Default RE: ZEX wiring
bump, anybody?
Old Jan 7, 2007 | 01:55 PM
redfireshaker06's Avatar
redfireshaker06
Do you mean the center console as where the arm rest and shifter are? If so, 2 screws on the top right near the hinge of the arm rest opening. And then the top layer just pops out. After you get around the shifter of course. Then theres 2 screws in the front of the lower piece (in front of the shifter) and 2 nuts under the little carpet piece in the bottom of arm rest center console. Then that just comes out. The 2 pieces on the side of the radio just pull out and then 6 bolts holding the bezel around the radio. 2 plugs in the climate control and then that comes out. And you will have easy access to get to run some wheres in the glove box. Now, one the right plug on the climate control is a PITA to get off. Theres a little lever thing you have to flip up to get the plug out. It's grey, you will see it. Hope this is what you wanted to know
Old Jan 7, 2007 | 09:25 PM
airbillster
YES! Thanks!
Old Jan 7, 2007 | 09:29 PM
redfireshaker06
Your welcome. I just went through all that Friday to run my system wiring
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
