Installing Mono Amp
Old Jan 7, 2007 | 03:45 PM
Speedyejl's Avatar
Speedyejl
Default Installing Mono Amp
I'm going to be installing a sub/amp later in the week. Not sure where to get the sound input from though.
Do the rear full range speakers have any low crossover cut off? (I'm not sure whether to assume so or not)
Would it be better to tap into the 8" subs post amp behind the dash (I've got the Skipper 500)?
TIA,
Eric
Old Jan 7, 2007 | 03:58 PM
Jerseyfury2's Avatar
Jerseyfury2
Default RE: Installing Mono Amp
ahh....if u got the Shaker 500 you might run into problems...those system's wiring setup is funky..don't know much about it.
-Mike
Old Jan 7, 2007 | 04:24 PM
blk05stang's Avatar
blk05stang
I tapped into my rear speaker wires when I installed my amp/sub. It sounds great and was much easier and cheaper then tapping into the wire in front. All you need is a line output converter to tap the rear speakers which cost about $20 at crutchfield.com
Old Jan 7, 2007 | 05:06 PM
Speedyejl's Avatar
Speedyejl
All right do you know what frequency those go down to?
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Art161
Sep 9, 2015 10:33 AM
TimeLord101
Sep 4, 2015 09:27 AM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
