UPGRADE THE HEADLIGHTS
#31
RE: UPGRADE THE HEADLIGHTS
ORIGINAL: Black GT
I installed the Noyka 45W fog light bulbs on mine and a few months later one of the black inserts melted and fell off. So they must burn hotter.
I will probably go the same route as LC06GT as these lamps really sit too high for fog lamps. They would be better served as driving lights. This would require a modification to the wiring harness as the fog lamps only come on with low beams and driving lamps are normally used with high beams.
#32
ORIGINAL: Centurion96
Thanks for the response. I'm always leary of brand names I've never heard of before. This is the case with both Luminics and Noyka. I would have to put these bulbs under load and see what kind of amperage they are drawing. Does anyone have any examples where the black inserts have fallen off with the factory supplied bulbs? When the black insert falls off, how does it effect the beam pattern?
ORIGINAL: Black GT
#33
ORIGINAL: PERTANO
I did the GT500 conversion on my car and later this year the HID's will come available. I think I'm going to hold off for them.
#36
[/quote]
Please tell us what HID kit works well? Are they high and low beams? Many on EBay and other places are not both[/quote]
The HID kit from stangmods seems to work very well. it doesnt replace the housing like the saleen, and it works fine from what i understand, also about 1/2 the price or less.
Ohfiveride has these, and did a great write-up on them, search for it
#37
[/quote]
#38
I got them on Ebay for 10 dollars shipped and they suck....dont fall for the scam in the since that the bulbs do not live up to the hype on the box. I ended up with silverstars and the output is actually better and brighter and whiter which is what I wanted for the extreme white PIAA fogs that I have from Cervinis.
ORIGINAL: stanngg
Anyone have any experience with these?
http://www.stangmods.com/Mustang-hea...bs-p/00433.htm
[IMG]local://upfiles/50034/217C09818A5F46DF836A9444403AF82D.jpg[/IMG]
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
