headlight switch removal
Old Jan 9, 2007 | 01:22 PM
woody77's Avatar
woody77
Default headlight switch removal
Hello all,
Quick question. Does anyone know the best way to remove the headlight switch? I am installing a Roush front fascia and need to get the headlight switch out to hook up the fog lights. I don't want to mark up the switch surround.
Thank you for the help,
David
Old Jan 9, 2007 | 01:43 PM
xbone's Avatar
xbone
Default RE: headlight switch removal
Havent tried it myself, but you could try pulling straight out on the ****, usually they are pressed on.
Old Jan 9, 2007 | 01:55 PM
howarmat's Avatar
howarmat
s197 Junkie
You have to remove the whole piece and it pops off quite easily. You may need something to pry gently with.
Old Jan 9, 2007 | 07:41 PM
Stone's Avatar
Stone
? do you have a V6 now and are going to replace the switch so you can turn on the fogs or headlight or you just going to wire it to the existing switch for all on lights.
Old Jan 9, 2007 | 07:48 PM
Rupp's Avatar
Rupp
If you have a putty knife, these work well. They are wide and therefor do not mar as bad as a screw driver would.
Old Jan 9, 2007 | 08:41 PM
06GT4RAD's Avatar
06GT4RAD
This is all I could find
http://bradbarnett.net/service_man/B...ment_Panel.pdf
Richard
StalkerGT
Nov 28, 2015 03:09 PM
jhawkr
Oct 30, 2015 01:55 PM
Colin Ringle
Sep 15, 2015 09:27 PM
wawagner82
Sep 13, 2015 09:02 AM
vintageaion
Sep 8, 2015 10:45 AM
