Help me here please!
Old Jan 18, 2007 | 06:57 PM
PRGT's Avatar
PRGT
Default Help me here please!
Hello everyone I have a bit over $400 to spend in my car. What should I buy? Panhard, LCA or a small brake upgrade? I'm opne to opinions. Thanks
Old Jan 18, 2007 | 07:30 PM
likemike99's Avatar
likemike99
Default RE: Help me here please!
if your eibach springs lowered your car then your pinion angle is off and the adjustable LCA can fix that and they are a good first step with suspension. if it is not lowered I would go with the panhard bar.
Old Jan 19, 2007 | 03:09 AM
Orion_240's Avatar
Orion_240
I'm assuming you DID lower it with the Eibachsso would agree with the adjustable LCA. If you do the work yourself and have enough left over, as you should, maybe you can get the beefier brake lines. Not enough there for new brakes though...
Old Jan 19, 2007 | 05:36 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I agree with the adj LCA's and get the panhard bar too!
Old Jan 19, 2007 | 09:14 AM
PRGT's Avatar
PRGT
In what do the panhard and LCA help me on the road and in the track? Will my track time change? Will my car spin the tires the way it is doing it?
Old Jan 19, 2007 | 06:35 PM
PRGT's Avatar
PRGT
Please give mesome advices?
Old Jan 19, 2007 | 06:44 PM
RodeoFlyer's Avatar
RodeoFlyer
right now your rear-end is off center from lowering the car - a panhard bar will re-center the rear end.
a set of adjustable lower control arms will correct your pinion angle and reduce wheel hop dramaticly
