Optima Battery
Old Jan 19, 2007 | 10:42 PM
PinupGirl77's Avatar
PinupGirl77
ROTM Moderator
Default Optima Battery
I need some help. We are having trouble installing a Red Top Optima battery. The hood will not shut properly with it installed. Has anyone had this problem?
Old Jan 19, 2007 | 10:52 PM
gatkins94's Avatar
gatkins94
Default RE: Optima Battery
Well, If the girl in that picture is you, and you drive a supercharged Mustang......I would think you could stop at ANY mechanics shop and get more help than you would EVER need!!!!
Seriously though, does the battery measure the same as the one that came out of the car? I would imagine there's only a small amount of room for a battery to be larger than the stock battery in that car....the engine compartment is quite tight.
Old Jan 19, 2007 | 10:54 PM
PinupGirl77
ROTM Moderator
Yup the pic is me
The batteries seemed to be the same size when next to each other. I think maybe the top posts could be a problem? I am thinking about moving the posts to the side of the battery.
Old Jan 19, 2007 | 11:13 PM
Sprzout's Avatar
Sprzout
ORIGINAL: photolabgirl77
Yup the pic is me
Dumb question, but...The Optima batteries come with an adapter/riser plate that sits underneath the batteries to help lift it up or keep the battery from sliding, in some cases. I know that's how it is in my '74 Vette. Are you using this adapter plate? If so, try removing it and see if the battery sits lower.
Old Jan 19, 2007 | 11:29 PM
Black06stang's Avatar
Black06stang
Are you married? j/k
Man, all I want in life is hot girl driving a hot car!
Old Jan 20, 2007 | 12:56 AM
Riven02's Avatar
Riven02
Jeez a girl cant even ask a tech question on here without getting hit on.......Its got to get old.
Old Jan 20, 2007 | 01:36 AM
Sprzout's Avatar
Sprzout
Ahh, she's attractive, but I've got a girlfriend...So I'm trying to help out by asking about that adapter plate. Sometimes it'll say that you "need" the adapter plate, but you don't actually need it. Our '67 Jaguar says, per Optima's website, that it needs the adapter plate; however, when you connect it up in the car, you don't need it because of the area that the battery slides into and how the battery is held down via a modified bracket.
Let us know if you get it to fit, though!
Old Jan 20, 2007 | 04:58 PM
PinupGirl77
ROTM Moderator
ORIGINAL: Riven02
Don't worry it does not get old Its ok.
I did not use the adapter and it still sat too high (when you closed the hood it stayed pushed up a little ). The guy at Discount Auto looked it up and it didn't show any Optima batteries that would fit a 2005 Mustang. So I had to go with a different battery that had recessed terminals. If I ever relocate the battery to the trunk, then I will get an Optima
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
mdj89
Oct 8, 2015 09:16 PM
logan409
Sep 26, 2015 07:43 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
