Need help quick!!!!!
Old Jan 27, 2007 | 02:30 AM
kingsmate20's Avatar
kingsmate20
Default Need help quick!!!!!
Ok, i'm having a major problem. I just got done installing a corsa axl back exhaust on my 2007 GT, and now she won't start. This afternoon i received my SCT xcalibrator from brenspeed. I programmed the car to 93 octane. After that was complete i started her up just fine. Didn't take her for a spin because I had the kids here with me. That was around 430. We started working on the exhaust around 930, and just finished up. I tried to start her, (remote start) and no go. It seems like she wants to turn over, she starts too, then she dies. I tried to start manually, and no joy. I gave up, and am now feeling a bit queezy. Does anyone have any suggestions?
Old Jan 27, 2007 | 02:36 AM
Cobrakev's Avatar
Cobrakev
Default RE: Need help quick!!!!!
Put the stock tune back in and see if that will work
Old Jan 27, 2007 | 02:38 AM
kingsmate20
I'll give that a shot just to get here started. But then what's the good of having my SCT? Something's not stirring the koolaid here. I'm so frustrated!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!![>:]
Old Jan 27, 2007 | 02:59 AM
kingsmate20
Well, a little progress. Flashed it back to stock. At the end of that it said check the fuel cap. Looked at it, it's on, thought maybe i didn't put it on all the way when i got gas. Started her up just fine...well maybe not just fine, but started none the less. So I tried to reprogram with the 93 tune. During that process the info on the odomotor said "FUEL LEVEL LOW DTE ODO DATA ERR"....after the program was complete it said to check the fuel cap. Tried remote start, and that cycles through 3 times if there is failure. First and second time no go. On the third time she started and idled, but sounded weak. It is 12am, so didn't want to **** off the neighbors anymore than I already have. At least she started.
LoLO's Avatar
LoLO
if its working with the stock tune then contact brenspeed they'lll send you another tune
Old Jan 27, 2007 | 07:10 AM
moosestang's Avatar
moosestang
ORIGINAL: kingsmate20
This is normal when chaning tunes if you don't pull the fuses it tells you to. the check gas cap afterwards isn't normal. I would also contact brenspeed.
Old Jan 27, 2007 | 10:58 AM
Stoenr's Avatar
Stoenr
quit using the auto start when testing the vehicle to begin with. Not sure how thats effecting it, but for working on the cars sake, use the key.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
