Sponsored by:
Sponsored by:
How do I make sure the 07 GT Premium has 3.55 final drive ratio?
Old 01-28-2007, 06:32 AM
NewMustang
NewMustang's Avatar
Default How do I make sure the 07 GT Premium has 3.55 final drive ratio?
How do I make sure the 07 GT Premium has 3.55 final drive ratio? I've heard that 3.55 is not a $100 option, not standard.
I went to ford to build one myself, I didn't see that option. When buying the car, this option should state on the spec sheet, correct?
NewMustang is offline
Old 01-28-2007, 06:36 AM
07AlloyGT
07AlloyGT's Avatar
Default RE: How do I make sure the 07 GT Premium has 3.55 final drive ratio?
the 3.55 is for the manual only. it is a $100 option and listed as such when you build your vehicle through fordvehicles.com.
it's there
07AlloyGT is offline
Old 01-28-2007, 07:15 AM
NewMustang
NewMustang's Avatar
Oh, I went to the wrong place the first time, that was for the 2006 models. Wow, you can even choose Nav System on a Mustang now!
Okay sonow thatthe 3.55 ratio is an option, that should be mentioned on the window spec sheet, right? I will make sure to make the one that comes with 3.55 ratio.
Thanks.
Old 01-28-2007, 10:21 AM
moosestang
moosestang's Avatar
Yes! It's an option and will be listed on the window sticker as such if it has it.
ORIGINAL: NewMustang
Thanks.
moosestang is offline
Old 01-28-2007, 10:23 AM
xbone
xbone's Avatar
Crawl underneath and look at the tag on the pumpkin.
xbone is offline
Old 01-28-2007, 11:41 PM
StowesStang
StowesStang's Avatar
ORIGINAL: xbone
+1......mine was on the sticker and stamped!!!
StowesStang is offline
Old 01-29-2007, 12:44 AM
Jerseyfury2
Jerseyfury2's Avatar
my v6 says 3.31[:'(]...lol haven't checked my GT yet
Jerseyfury2 is offline
Old 01-29-2007, 02:59 AM
Embalmer
Embalmer's Avatar
You can see I ordered mine with the 3.55 limited slip.
Embalmer is offline
Old 01-29-2007, 03:02 AM
Orion_240
Orion_240's Avatar
as long as you're checking the Ford build-it-yourself site, is it true that you can't get the 3.55 w/ the Auto?
Orion_240 is offline
Old 01-29-2007, 09:45 AM
Cobrakev
Cobrakev's Avatar
True, Ford would not put the 3.55 in my 07 Auto Gt when I ordered it
Cobrakev is offline
squishbang
12-04-2015 02:29 PM
JonnyBlazeGT
11-03-2015 01:10 AM
chain
08-17-2015 08:52 AM
ccwebb
08-11-2015 06:47 PM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: How do I make sure the 07 GT Premium has 3.55 final drive ratio?
