07's slower than 06's
Old Jan 31, 2007 | 08:56 PM
s2k's Avatar
s2k
Default 07's slower than 06's
WellI was doing some research and found out the 07 GTsare slower (3-5 tenths of second, which is basically CAI & a tune) due to added weight from the GT500 but they handle better or so I read. Can any confirm the ride difference between the 06's and 07's?
Old Jan 31, 2007 | 09:09 PM
LegallyTorchRED's Avatar
LegallyTorchRED
Default RE: 07's slower than 06's
They are heavier, so ... 0-60, trap times , and 1/4 mi ET's will be slower. I'm not sure that FORD would have added the upgraded suspension package into the GT's. So, I feel they won't handle any better, or worse, than anyother GT.
Now, if they handle better, as you read, but are slower, then it's gonna be a "wash"
Old Jan 31, 2007 | 09:31 PM
SRT_what's Avatar
SRT_what
What exact changes did they make to the GTs in '07 to accomodate the GT500 model? Can they be removed?
Old Jan 31, 2007 | 09:35 PM
my77stang's Avatar
my77stang
i thought i heard somewhere there was body / structural stiffening they did which would account for better handling but still using stock suspension parts
Old Jan 31, 2007 | 09:48 PM
LegallyTorchRED
The front was stiffened, and heavier crossmembers addedto accept the 5.4 steel block in the GT500's.
The regular GT has the same parts. FORD decided to use the same chassis, and eliminate, dual production.
Old Jan 31, 2007 | 10:51 PM
SRT_what's Avatar
SRT_what
Ok, I can understand those parts, but is that enough added weight to make up to a 1/2 sec. difference in the quarter? Can't be more than like another 100lbs or something. Maybe I'm wrong.
*Edit- sorry if I seem a little obsessed with this, but if there's any truth in this, I'm going to be pissed. I would have purchased the '06 left over instead of the "heavier" '07. After doing some research too, Motortrend claims that the '06 and '07 GTs weigh the same, 3,483, while the new GT500 weighs 3,920 for the coupe, and over 4,000 for the vert. I'm sorry, but I don't see how Ford could get away with adding nearly 500lbs to a stock GT. That car would be a turd!
Old Jan 31, 2007 | 11:05 PM
07GT's Avatar
07GT
ORIGINAL: s2k
Care to tell us where you read about this? My 07 weighs 3436 lbs, stock, and it's not stripped. 3 to 5 tenths would be a lot of weight difference. More info please.
Old Jan 31, 2007 | 11:14 PM
xbone's Avatar
xbone
07's faster than 04's.
Old Jan 31, 2007 | 11:20 PM
dkegel's Avatar
dkegel
ORIGINAL: 07GT
Did you get this weight from weighing the car yourself? I'm curious because everything I've read shows that the '05s (and I assume 06's) weigh 3560 - 3575. I can't see how your '07 is 100 lbs lighter than that. Of course, there will be some variances depending on how much gas is in the car and whether or not you have the Shaker 1k or not.
Dave Kegel
Old Jan 31, 2007 | 11:21 PM
Doc Holiday's Avatar
Doc Holiday
The stiffening adds638 lbs.
[sm=joke.gif]
