RAPTOR SHIFT LIGHT HELP
Old Feb 2, 2007 | 07:51 PM
mvm549's Avatar
mvm549
Default RAPTOR SHIFT LIGHT HELP
alright so i got my shift light today and started to install it. i have some questions though
ive pulled the pillar thing off and got the wire through and down but how do i get it through the firewall or wutever. ive looked at the pics online and still cant figure it out.
also how do you disconnect the battery, i just wanna be sure and not to mess it up.
Thanks
Old Feb 2, 2007 | 07:59 PM
moosestang's Avatar
moosestang
Default RE: RAPTOR SHIFT LIGHT HELP
This is where I ran my linelock wires through the firewall. I'll try to explain how to find it as best I can.
From inside the engine compartment feel the firewall below and two the right of the master brake cylinder. You should find a small round rubber stopper/gasket that has nothing running through it. Pull it out. Now to find the hole from inside the car you need to pull up on the insulation just above where the carpet stops. there's a round white piece of plastic attached to the insulation, the hole is behind the insulation just above and to the left of this piece of plastic. You'll need to feed the wire around the insulation on the left and through this hole, then punch a hole in the rubber gasket using a screw driver to feed the wire through. Run the gasket down the wire and push it back in the firewall.
Now I have no idea where you connect the wire for the shift light, sorry.
ORIGINAL: mvm549
Thanks
Old Feb 2, 2007 | 10:14 PM
mvm549's Avatar
mvm549
ok i got it through
how do u disconnect the battery?
Old Feb 2, 2007 | 10:36 PM
moosestang's Avatar
moosestang
Just disconnect the negative battery cable (black wire) with a wrench or socket. I really haven't looked to closely at the battery connections, but you want to disconnect the negative cable and make sure it's not touching.
Oh, and don't lay your wrench across the positive and negative posts on the battery. that will make nice sparks.
Old Feb 3, 2007 | 01:36 PM
Hiboost's Avatar
Hiboost
Use a testlight or voltmeter to determine what fuse is hot with the key on the ON position. I can look for you later when I go to the garage. You have to pull a couple of screws out of the fender liner to get to the hole where you can run the wire....
Old Feb 3, 2007 | 02:09 PM
moosestang's Avatar
moosestang
ORIGINAL: Hiboost
Not if you follow my instructions.
Old Feb 3, 2007 | 04:52 PM
mvm549's Avatar
mvm549
ya ive got it through now i just need to hook it up to the battery and the other stuff
Old Feb 3, 2007 | 04:57 PM
randybobr's Avatar
randybobr
You need a light to tell you when to shift ?
Old Feb 3, 2007 | 07:15 PM
scramblr's Avatar
scramblr
It's handy for the track, especially with the tach on the wrong side. Still don't understand why Ford did that![:@]
Old Feb 3, 2007 | 10:33 PM
moosestang's Avatar
moosestang
I'd like one to keep me off the rev limiter, which is set at 6800rpms now. When you're moving this fast looking down at the tach is a pain.
ORIGINAL: randybobr
degner122
Sep 16, 2015 07:09 AM
Colin Ringle
Sep 15, 2015 09:27 PM
Mustangmalo
Sep 6, 2015 05:22 PM
amandahchase
Sep 3, 2015 10:09 AM
