A new question about Charge motion plates
Old Feb 6, 2007 | 03:55 PM
  #21
CrazyAl's Avatar
CrazyAl
Default RE: A new question about Charge motion plates
The fuel line tool can be had at any auto parts store. They are very cheap. Though, I have been told it's possible to install the CMCP delete plates without it. Apparently there is a way to rotate the fuel rail out of the way.
As for the MPG, I watch my mileage very carefully. I do it based on my odometer readings and my fill-up reciepts, not the in-dash computer (which is horribly inaccurate). I installed my CMCP deletes the at the same time as I installed UDPs. I saw no change in mileage--city, highway, or combined, before and after.
If you are looking for an article about them, here's one:
http://mustang50magazine.com/techart...mrc_delete_kit
Old Feb 6, 2007 | 04:17 PM
  #22
2oo5stang's Avatar
2oo5stang
that's the same link i posted. I heard something about not having todisconnect the lines and fliping them over to the driverside but wish i would see pics. well, i guess i'll find out when i do the swap.
Old Feb 6, 2007 | 06:38 PM
  #23
Chevy Convert's Avatar
Chevy Convert
So Al, since you are ther resident expert, give it to me straight...
I emailed Brenspeed about a tune for the plates. Brent replied that a reduction in low end torque is noticeable and the best way to offset it with gears. He does not recommend doing the mod w/o doing gears as well.
I plan on doing gears at some point, but I want to make sure the CCMV delete mod is really worth it.
Is a reduction in low endtorque noticeable?
Old Feb 7, 2007 | 02:10 PM
  #24
Chevy Convert
So no one can answer the question?
I'd search but there are million CCMP, CCMV, CCCP, threads out there.....
Old May 5, 2007 | 04:04 PM
  #25
probinator's Avatar
probinator
sorry to bring this back but can it be done without the special tool? My buddy pretty good mechanic wise but wants to know, and if so what did u guys do?
Old May 5, 2007 | 05:45 PM
  #26
scramblr's Avatar
scramblr
ORIGINAL: probinator
Yes, all you have to do is after disconnecting the COPS, just pull out the injectors. Then flip the harness from the passenger side to the drivers side and lay it upside down out of the way. Then proceed with the install. Here's a write up, just diregard the part about disconnecting the fuel line.
http://www.2005stang.com/gallery/alb...CMCVdelete.pdf
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
dudeguy421
Sep 24, 2015 11:16 AM
maestro1024
Sep 21, 2015 02:40 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
