tuner question
hey guys, i just recently bought a catless X pipe which i like alot. The only problem is that i get a CEL since its catless and i was wondering if the diablosport tuner will help with this. Also i was wondering if i will gain any power and how the tuner works with my mods...like does it adjust itself by figuring out my mods like in the M3? In a couple weeks im going to be buying an intake and was hopeing that i wouldnt have to spend the money on a custom tune before i spring for a turbo in a couple months
thanks alot zach
thanks alot zach
You can use the Predator to turn off the rear o2 sensors. You will be fine running a Diablo canned tune for now. You can also get a set of MIL elimintors to plug into the o2 sensor harness to eliminate the light.
The CEL being on won't hurt anything, so get most or all the parts you can, then get the tuner and have brenspeed do the tunes. That way you can knock it out, then later get a dyno tune. If you buy parts from Brenspeed, they will supply another tune for that part, if it needs it, for free. If you buy the part from someone else, then Brenspeed will charge you a certain amount for the tune, like 75 bucks for one tune or 125 for 3 tunes. So get everything and then get the tune.
Luke9222
Oct 22, 2015 11:55 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
ernesto-619
Sep 10, 2015 01:32 AM
