Light switching problem
Old Feb 15, 2007 | 04:10 PM
Spiffu's Avatar
Spiffu
Default Light switching problem
I think the wiring/circuitry that controls what light combination on my GT is busted. Normally you turn the **** to the right once, the running lights come on, you pull the **** out, the center lights come on. You push the **** in and turn it to the right again and pull it out a gain, all four lights and running lights should be on right?
When I do the latter, the center lights don't turn on when I pull the **** out. Only the main and running lights turn on.
I'm guessing a wire is snapped or a control circuit busted somewhere because it use to work....or I just forgot how to do it.
Old Feb 15, 2007 | 04:26 PM
DaBoss's Avatar
DaBoss
Default RE: Light switching problem
Make sure the engine is running. If not only the headlamps turn on. The driving/ fog lights only turn on when the ingnition is on.
Old Feb 15, 2007 | 07:42 PM
RICAKILLA's Avatar
RICAKILLA
And make sure your highbeams are not on, the middle lights turn off when the highs are on
bond007
Aug 26, 2015 11:36 PM
1st 4 eyed fox
Aug 15, 2015 02:16 AM
drumhedd2005
Aug 13, 2015 09:59 AM
cody.hoeppner
Aug 12, 2015 06:39 AM
cody.hoeppner
Aug 11, 2015 08:08 PM
