Saleen supercharger potential
#41
Saleen SC capable of 400+= yes
Stock block will not handle more than 8-9lbs of boost safely= That statement is dead wrong, its not just about the boost its also about the tune, I have been running the 3.4 pulley making 9-10lbs of boost without any issues. I know several people pushing 10lbs without problems, and have a buddy pushing over 12lbs on the stock block putting down 520hp to the ground, granted he can get 93octane at the pump which helps.
8-9lbs of boost will keep your car in the 380hp range= If you are only making 380rwhp on 8lbs of boost your tuner is on crack, I was putting down 438rwhp on 6.5lbs of boost.
But to answer the orginal post. Could you see 600+ rwhp running a Saleen SC, yes but not without some serious work.
#42
are u stoned or stupid? maybe ur thinking of the new edge models.
#44
Everyones numbers are going to be slightly different since each car is different and depending on what area of the states your in. I would suggest finding someone near you and looking at their tune to know what you will put down. Yes, 600RWHP is capable on these blowers with mods and engine work.
#45
If you want to see the potential of Saleen S/C's go to Brenspeeds site and click on customers at the top of the page and scroll down. They've installed a gob of them with different power levels. I believe around 15lbs of boost is possible with the Saleen with smaller pulley and o/s crank pulley. If you keep it below 10lbs of boost and have a good tune your motor should hold up some time. The stock block is good up to 800 h.p. but the stock internals are a different story. 450rwhp makes for a fun street car, once you go above that your probably looking more at a strip car and should build accordingly.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mungodrums
09-28-2015 10:54 PM
09-25-2015 06:42 PM
34, diablo, forums, hp, max, performance, potential, pully, rwhp, saleen, sc, stock, supercharged, supercharger, tunes
