Gears
Old Feb 22, 2007 | 09:55 PM
1BADD05's Avatar
1BADD05
Default RE: Gears
I have heard that a 4.10 in the GT should Pull you back in your seat when you take off, but It doesn't seem that drastic a difference than stock.
Old Feb 22, 2007 | 10:07 PM
Arwing's Avatar
Arwing
Default RE: Gears
ORIGINAL: 1BADD05
hmm, maybe I should start looking into some 4.30's then...
Old Feb 22, 2007 | 10:13 PM
RUFDRAFT's Avatar
RUFDRAFT
Default RE: Gears
My 4.10's are great.
I think what you're experiencing is caused by the drive by wire system - the revs don't fall off as quickly as you're used to - they hang a bit.
Mine got better after the SCT tune - but it's still an adjustment for me.
Old Feb 23, 2007 | 02:49 AM
jerseyblood's Avatar
jerseyblood
Default RE: Gears
Overall I am very happy with them. I did notice a definite difference in acceleration the day I picked the car up. Like anything I got used to it. For a daily driver, the gears and Hurst are pushing the comfort level for me. The shifter has broken in since, making it a little better. I have the Motive gears because they were a present and they do whine slightly. I kinda like this so not an issue in my book unless it gets worse and louder. I think I got them for 150 on Brenspeed and yes all I did was set the perameters for 4.10 on my SCT and speedo dialed right in.
Old Feb 23, 2007 | 10:00 AM
2oo5stang's Avatar
2oo5stang
Default RE: Gears
i'm going with 4.30's for sure. With those, cruising in 5th gear at 80mph, it will be at 2850rpms and that's awesome. The 4.10's should still put you in your seat, are you sure they installed the right gears or ripped you off? The tune, like mentioned, will be for your throttle lag and just to adjust your speedo for the gear swap. The throttle lag could be hurting but shouldn't be that much.
Use this if you want to see what rpms you will be at with different gear ratios and your speed.
http://www.speedshoppro.com/Download...g_0506_V8.html
Old Feb 23, 2007 | 12:50 PM
28HopUp's Avatar
28HopUp
MF Administrator
Default RE: Gears
I just had 4.10's installed in my 4.0L/5spd. Here's a post I made about my initial impressions -
Don't Fear 4.10's
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
