Spontaneous trunk opening
Wow I thought I was the only one!
I have figured out why it happened though. It was only while I was driving. I had a banana box in my trunk, with some stuff in it. I guess everytime I took a turn on something the box moved and it would catch the lid.
I tucked in the little lid/latch w/e you call it into the hole so it's not hanging down. Never had a problem since then. It's sort of stuck in there (not really stuck but good enough not to fall out by itself)
Try doing that and see if it helps
Ya that happened to me once but I thought it was my coat sleave caught something on the left side of seat. I searched for a half hour looking and couldn't find any switch. I figure I hit the keyfob at the same time. Do you have any other keys etc.on the key chain? If so remove them and see what happens.
On the threads that have discussed installing a truck-opening button in the interior - it all has to do with locating a certain wire, and then setting it up to ground when a [newly installed] switch is activated.
Thus, it is possible [my speculation] that somewhere along the path of this wire, the insulation is cut or scraped; or possibly the wire itself is pinched around a corner or something. All it would then take is the right bounce or bump to establish aground - and the truck pops. The effect would be the same as pushing a truck-open button if the vehicle had one.
I have not read of this problem before this thread. My thought above is a guess.
I'll be more careful. I also orginally thought it was the yellow latch inside the trunk that may have caught something but my trunk was empty last time. Thanks for all the input.
Used to happen to me, and I thought there was aproblem with it. That was until I realized it was my sub moving around in the back pushing on the release handle on the inside. If it happens at the same place or same time, that means there is something causeing it. Maybe your knee hits the fob, or something taps the latch in the trunk.
- C
- C
Agree
ORIGINAL: myredgt
- C
- C
i have a couple of 12's in my trunk and was wondering if anyone had issues with the trunk saying its open while the bass is up really loud? was wondering if anyone has found a way for this annoying beeping to stop "other than turning down my music lol"
I had an 03 coupe, and there was a feature that made the trunk opener on the key fob inactive while the car was running. I was surprised to find out this feature isn't the same on my 07. The trunk CAN BE OPENED by the key fob while the car is running!! I've also had to adjust my 07'strunk latch to make sure the gaps are even on the right and left side. After adjusting, my trunk also closed better too.... more secure. It's unlikely that cargo in the trunk is catchingthe emergency opening latch inside the trunksince it's secured better in the05+. The pre-05's were just hanging loose, and I never had this problem. FYI...The 05+ model also doesn't have the button in the glove box to open the trunk that my 03 had (whichCOULD open the trunk while the car was running).
