A/C Problem..
Old Mar 5, 2007 | 08:00 PM
ANBAUTO's Avatar
ANBAUTO
Default A/C Problem..
So over the weekend it was nice out and I finially wanted to use my a/c again. WellI went to turn it on and the a/c doesnt work! i dont hear the clutch engauging the compressor. I only have 13k miles on it. Has anyone else ran into this problem?
Old Mar 5, 2007 | 08:02 PM
Arwing's Avatar
Arwing
Default RE: A/C Problem..
Haven't had that problem...yet[>:]
Just take it to the dealer
Old Mar 5, 2007 | 08:46 PM
howarmat's Avatar
howarmat
s197 Junkie
Does it blow any air out at all?
Old Mar 5, 2007 | 10:10 PM
ANBAUTO's Avatar
ANBAUTO
It blows air out at about the same temp it as a regular day its not hot but not cold either... Ive looked at all the fuses and nothing... im just scared to take it to the dealer since i have so many mods on it.
Old Mar 5, 2007 | 10:15 PM
Caution's Avatar
Caution
Hrmm -- that sucks... i haven't had that problem at all... take it to the dealer and see what they say... ehat do you have to loose? Worse case scenario is they tell you no... but what mods do you have to effect your A/C?
Old Mar 5, 2007 | 10:18 PM
howarmat's Avatar
howarmat
s197 Junkie
I had the problem when i changed out the radio. I did not hook the connector just behind the dial on the passenger side up tight enough. If you havent had you dash apart this would be unlikely though. Did you check the fuses in the passenger side kick panel and also under the hood?
Old Mar 5, 2007 | 10:20 PM
mlcrycc's Avatar
mlcrycc
I know this sounds stupid, but................
a couple of weeks back, it was cold out, so obviously I used the heater in the morning...couple of days later, when it warmed up, I just turned the dial from hot to cold....forgot to depress the button below the dials to turn on the air.......did you check to see if it was illuminated??
I know, I know.......
Mike
Old Mar 5, 2007 | 10:30 PM
Caution's Avatar
Caution
Wow --- user error will kill ya[:@] .. funny though
Old Mar 5, 2007 | 11:20 PM
ANBAUTO's Avatar
ANBAUTO
well the s/c ic pipes make me remove some of the ac bracket lines for clearance and you know dealers they are picky as hell when it comes to warrenty work. I did check the fuses in the kick panel and under the hood and they were also good. Yes i did check for user error as well hahaha
vargas
Jun 17, 2017 12:17 PM
69Volunteer
Sep 30, 2015 10:39 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
HIS S-197
Aug 10, 2015 05:47 PM
