Question about lowering rear only.
I just wanted to get some info on just lowering the rearend, do you have to adjust anything after putting the springs on or are you good to go right off the bat? I was thinking about getting the eibach prokit but I kinda think the front sits low enough for me already.
You need to adjust your pinion angle (requires adjustable LCAs or UCA) and your rear axle offset (requires adjustable panhard bar).
On some cars you can get away without the panhard bar, but it is needed most of the time.
ORIGINAL: CrazyAl
inyadreems
Aug 21, 2015 09:10 AM
