BMR Suspension...Road Test..
RE: BMR Suspension...Road Test..
Lowering Pics... Rear..Drop 1.75 inches...still plenty of room as you can see
You can see the pic in my Sig...My car was freakishly High..
[IMG]local://upfiles/19878/98891B7172F1446FBDBD0329E462E44F.jpg[/IMG]
Dude, the stuff is the bomb, no doubt about it, LOVE IT!!! Our car is on rails dude, no doubt about it. When we hit a hard bump in the car it does make some noise in back end, do you have that problem also? No biggy really, but that is what you get when you modify a car right?
I have a very similar setup to Torch (and then some) and there should be NO odd noises when you go over bumps. If that is happening to you then chances are that you have a loose bolt somewhere in the rear suspension. Make sure all the control arm bolts are torqued to 129 ft-lb.
Crazy Al is right..I have no weird Noises as of yet..But i have barely driven the car..
You should look into your strange noises..it should be solid as a drum..
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
inyadreems
08-21-2015 09:10 AM
LMPerformance
01-20-2005 01:42 PM
