Fiberglass sub box
Old Apr 5, 2007 | 09:04 PM
  #31
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Fiberglass sub box
It looks good! I might suggest putting the specs that the speaker should have to sound good with the boxes in the thread. Not all speakers sound good in a sealed box or with the specific volume you've given.
Old Apr 5, 2007 | 09:38 PM
  #32
Anarchy Customs's Avatar
Anarchy Customs
ORIGINAL: Derf00
The sub I used when building this box was an 10 inch MTX Thunder 7500. The box is 0.71ft3 which is what many 10 inch subs in a sealed enclosure would operate idealy in. Since it is a sealed enclosure you have a little +/- room with the air space. If some ones sub called for 0.6 or 0.8 ft3 of airspace this box would be fine. Only the most hardcore of audiophiles would notice the difference. And unless some one is build a system designed for SPL, they wouldn't notice a difference either.
The mounting depth is 7 1/8". And overall diameter is 10 7/8". Any subs falling within those parameters will work.
I don't have any plans to mass produce any ported enclosures at this time. With ported boxes the specs and tuning need to be exact to the specific sub that the customer would be using. So any boxes like these would be made on a one-off basis and thus the price would be more. But if someone wanted one I would make it.
Old Apr 27, 2007 | 10:36 PM
  #33
Anarchy Customs
OK guys and gals, I told you I'd keep you updated as to when I'd have some of these available. Well here they are:
http://cgi.ebay.com/ws/eBayISAPI.dll...;rd=1&rd=1
I have a similar setup which houses two 10 inch subs which should be listed with in the next few days also. Thanks again for everyones positive comments!
Old May 10, 2007 | 05:40 PM
  #34
Anarchy Customs
More updates:
The dual 10" sub boxes are now done and ready. 1.43ft3, sealed, mono chamber. Sorry the pics are crappy, the lighting in my garage sucks and the cars filthy.
Old May 10, 2007 | 05:45 PM
  #35
skilz4u2nv's Avatar
skilz4u2nv
Looks great... did you build the box in the trunk? Cuz wouldnt it be hard to fit it in through the trunk opening?
Old May 10, 2007 | 06:36 PM
  #36
Anarchy Customs
No, its easy to fit in the trunk. The actual enclosure and the carpeted panel are two seperate peices. You just put in the box first then put in the panel and attach it from the inside of the box.
Old May 10, 2007 | 08:26 PM
  #37
zid3's Avatar
zid3
very nice work... i should show u the setup i have in my car i thinkull like it the only downside it takes up the whole trunk.. damn sub needs like 2.0 air space vented but its a great sub
Old May 10, 2007 | 11:53 PM
  #38
skilz4u2nv's Avatar
skilz4u2nv
POST PICS!!
ORIGINAL: zid3
Old May 11, 2007 | 12:52 AM
  #39
Anarchy Customs
ORIGINAL: zid3
I feel ya. I'm working with a guy right now to fit a 13w7 in his stang. It only needs 2.38ft3...[sm=headbang.gif]
Old May 11, 2007 | 08:57 PM
  #40
Anarchy Customs
I've been getting a lot of pms about these boxes so for those who are interested here you go:
Thanks again everyone for the compliments on my work.
