Headlight Fuse
Old Apr 6, 2007 | 08:40 PM
LesteR723's Avatar
LesteR723
Default Headlight Fuse
I looked through my manual and only found a fuse number for high beams and fogs... can someone tell me where the headlight fuse is and what number? Thank You.
Old Apr 6, 2007 | 08:46 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Default RE: Headlight Fuse
There is no fuse directly for each headlamp. They get power from the bussed electrical center and through the smartjunction boxmodule.
Old Apr 8, 2007 | 11:37 AM
LesteR723's Avatar
LesteR723
what else is hooked up to that? woudl it be safe to wire in a couple interior 12" neons to that?
Old Apr 8, 2007 | 01:41 PM
PROMETHEUS PRIME
Are you looking to have them on when the headlights are on, or on a switch?
Old Apr 8, 2007 | 03:24 PM
doode's Avatar
doode
ORIGINAL: PROMETHEUS PRIME
hi-jacking this thread
im up in Canada, and have DRL
i want to get HID's , but obviously want to disable them so they dont stay on whenever the car is running and ebrake is down, just when i actually turn on the headlights
like you said, there is no real fuse. would i screw something up if i put a swtich in the power wire for the headlights between the SJB and the actual headlight? essentially that switch would control whether the headlight gets power or not
TIA
Old Apr 8, 2007 | 04:58 PM
LesteR723's Avatar
LesteR723
i just got anxious and used a switch, thank you for the help though!
Old Apr 8, 2007 | 08:45 PM
PROMETHEUS PRIME
ORIGINAL: doode
TIA
The DRL I believe are a programable perameter for the Smart Junction Box. I haven't tried it yet. The dealermight be ablt toturn it off if not illegal
Old Apr 9, 2007 | 02:11 AM
doode's Avatar
doode
ORIGINAL: doode
TIA
by law every car 1991 and newer must have DRL
hackshack fixes are the only way to get around it heh
Old Jul 6, 2007 | 10:22 AM
lavila07's Avatar
lavila07
I'm having a similar problem. I wired my HIDs without changing anything else and now the lights sometimes refuse to power ON or can flicker at times. There are times though where I have no issues with them. I havethem setup to turn ON when I turn the headlight switch on.
Can anyone please let me know the best action to take or what I have to buy in order to get these lights working properly? Thanks.
jwog666
Dec 27, 2021 08:09 PM
StalkerGT
Nov 28, 2015 03:09 PM
Drastang
Sep 29, 2015 03:31 PM
daytooday
Sep 20, 2015 10:55 AM
wenmill
Sep 11, 2015 07:07 AM
