Sponsored by:
Sponsored by:
Dash Board SquEEEEEEK?
Old 04-10-2007, 10:39 PM
Jackies Stang
Jackies Stang's Avatar
Default Dash Board SquEEEEEEK?
AnyOne have a dash board squeeeeeek? It is driving me nuts. I see some foam between thedashand the windshield and have tried to tuck it back down under the dash but now it is worse! Any suggestions?
Jackies Stang is offline
Old 04-10-2007, 11:06 PM
spuddogg
spuddogg's Avatar
Default RE: Dash Board SquEEEEEEK?
I have an intermittant squeeeeeek around the passenger side dash (by the glove box near as I can figure), another in the driver side A pillar as well as the driver side door.
Oddly enough, the guys at the dealer never seem to be able to hear any of them.
Ah well, I just turn up the stereo or downshift when it gets annoying.
If you have insulation poking outta the dash at the windshield that should be a warranty fix, I'd think.
spuddogg is offline
Old 04-10-2007, 11:29 PM
2cokeman
2cokeman's Avatar
My dash squeeks in the middle, dash area, worse when cold, drives me nuts too!
2cokeman is offline
Old 04-10-2007, 11:54 PM
Big McLargeHuge
Big McLargeHuge's Avatar
Yeah, mine squeaks near the glove box once in a while. I haven't mentioned it to the dealer yet, but I probably will next time I'm there. Vaguely annoying, but somehow I doubt they'll find anything.
Big McLargeHuge is offline
Old 04-11-2007, 12:02 AM
Menace
Menace's Avatar
Mine squeaks everywhere, cold or warm...
Menace is offline
Old 04-11-2007, 12:09 AM
feejay
feejay's Avatar
ORIGINAL: Jackies Stang
Hate to tell you this, but take it to the dealer. There is a TSB for the squeaky dash. Sorry I dont have the number handy.
feejay is offline
Old 04-11-2007, 12:28 AM
BAMASTANG06
BAMASTANG06's Avatar
I have this same problem and it has been mentioned on here several times before. I don't have the link but someone posted a method to fixing this problem and I used this method but couldn't locate the area under the dash that they metioned the noise comeing from. The method involves removing the A-pillar cover which runs fromthe winsheild to above the door window back to about where the seat belt is. This cover basically is held on with two hooks toward the winsheild and 3 snaps above the door. Once you remove this you can use a flash light to see underneath the dash. I took a long screwdriver and rolled a slightly thickened amount of black Nylon Tulle around it the I stuck that under the dash through the opening to the point where I thought the squeak was coming from and then I picked up on the dash and wedged this material into it futher then used the dash to grab the materal. I used this material because its black and waterproof just in case. Be carefull on the passenger side because there are alot of wires that you could damage. I don't know for sure that this targeted the exact area of the squeak but I do know that it tighted the dash up. Also you can stick some up under the dash by going under the dash where it meets the winshield. After I did this I road around on the same roads where the dash usually squeaks and I couldn't make it squeak no matter how hard I tried so far now I think I have fixed this problem. I would normally say just take it to the dealer but I have done that 3 times and they never fixed it.
BAMASTANG06 is offline
Old 04-11-2007, 03:11 AM
Orion_240
Orion_240's Avatar
I wouldn't call it a "squeak... maybe a "creak"...
And yes, it mainly happens when it's cold and isn't readily reproducible for the service techs to check it out!
In tomorrow for oil change and I'll ask if I can leave it for any TSB's
Orion_240 is offline
Old 04-11-2007, 11:04 AM
redfireshaker06
redfireshaker06's Avatar
I am having the passenger side squeak. Only when its 60 or below. lol. The drivers side A Pillar, I had that. Just hit it. One of the snaps isn't it far enough. That fixed my problem. I have the damn seat squeak but nothing is loose. Its wierd
redfireshaker06 is offline
mrtrodonet
09-19-2020 03:12 PM
chrisdbassplayer
10-13-2015 06:53 PM
lincolnshibuya
10-06-2015 08:45 AM
Urambo Tauro
10-05-2015 09:37 PM
breaking
10-02-2015 01:27 PM
Quick Reply: Dash Board SquEEEEEEK?
