Best Suspension for 05 GT
I want suspension that will give me the perfect drop. Fenders right above the tires. I haven't really seen s197's with the drop im looking for. Coilovers could probably do the trick but I want a smoother ride so those are out of the picture unless someone has anything to say. thanks
RE: Best Suspension for 05 GT
Eibach, they have the sportline and the pro kit, check those out. Don't forget if you drop it there are other parts you will need to add/change. New panhard bar, lower control arms, upper control arm and shocks/struts. use the search cuz there are plenty of posts by CrazyAl regarding suspension.
ORIGINAL: DeStonn
all this other stuff will modify how well the springs will feel but you dont need them
dont see why everyone on here says that you need 1k in suspension just to change your springs
it's intereting that the frhp doesn't drop you
far enough, to need uca's,lca's or a new panhard par
i am considering this option, among others
[IMG]local://upfiles/37808/4E3B90BC1D9B4159BB6F8ED47471C2E2.jpg[/IMG]
ORIGINAL: justmachit
ORIGINAL: Vista_Blue_GT
if you use the pro kit you dont need anything but the springs...and if you get the sportlines all you need is c/c plates and a bumpsteer kit
ORIGINAL: DeStonn
I'm only planning on dropping the rear of the car and when i do that, i'll get an adjustable panhard rod and i'll be doing either QA1 shocks/struts or Tokico D-specs at the same time (fully adjustable so I can adjust for drag strip use, and readjust for street).
Matt's 95 Stang
10-05-2015 07:16 AM
