Won't pass inspection!?!?
Old Apr 27, 2007 | 12:32 PM
05CLASSIC's Avatar
05CLASSIC
Default Won't pass inspection!?!?
Had my car at the stealers the other day and noticed that the inspection is due so I had them renew it. The service writer comes back and says it didn't pass, something about the sencers or something. I'm running a 93 tune w/CIA---do I have to be it back to stock or should I just have local shop inspect it.
Old Apr 27, 2007 | 12:38 PM
hammeron's Avatar
hammeron
Default RE: Won't pass inspection!?!?
it seems for you, it would be very easy to return
to the stock intake, airbox and tune. i would try
that and see if it passes
another option is to try a lower octane tune if you have one.
ie 87 or 91
Old Apr 27, 2007 | 12:50 PM
Lees07GT's Avatar
Lees07GT
It has been my experience that my cars have always passed with flying colors at my local inspection station. At the dealer, however, they usually find something that fails. Once, they told me my wiper blades were worn whenI had, in fact,just replaced them about a month earlier. Not to be one of those conspiracy theorists, but I have a sneaky suspicionthat stateinspections may be a real bread and butter money maker for the dealer service departments. Ever since my wiper blade fiasco, I have avoided dealer inspections like the plague.Just my 2 cents.
Old Apr 27, 2007 | 12:55 PM
05CLASSIC's Avatar
05CLASSIC
I've always tried to avoid dealships in the past.
Just wondering, do the smaller local shops hook it up to a machine like the dealerships do?
Old Apr 27, 2007 | 01:01 PM
Jays Mustang's Avatar
Jays Mustang
Not knowing what your state emissions requirments are, your tune might be doing it. But if he said you have a bad sensor why didn't he tell you which one? Or was he just guessing. Probably just put the tune back to stock and it should pass.
Old Apr 27, 2007 | 01:02 PM
07GTEddy's Avatar
07GTEddy
ORIGINAL: 05CLASSIC
When do you have to have an inspection?
New cars in Cali, are 5 years exempt, then the fun begines..............
Old Apr 27, 2007 | 01:04 PM
ErcWrestlr's Avatar
ErcWrestlr
My local shop just gives me the stickers and tells me whats wrong. They never hold me from passing the inspection.
Old Apr 27, 2007 | 01:09 PM
S1ckStang's Avatar
S1ckStang
try reading dtcs and maybe erase them because it mite jus be a faulty sensor.
Old Apr 27, 2007 | 01:13 PM
Lees07GT's Avatar
Lees07GT
ORIGINAL: 05CLASSIC
I would guess that it would depend on your particular state and local laws regarding inspections. But one problem we have in Virginia is that they scrape your current sticker before they start the inspection. So if they claim you fail for a worn wiper blade, you have to let them replace it or you fail and they mark your car for failure with a special "failed inspection" sticker which allows you ten days to get the problem fixed. But you can't just go to another inspection station and hope to breeze through because you have been "marked" and they are probably going to check you even closer than usual. In my locality, it's best to find a good, honest inspection station and never go anywhere else.
Old Apr 27, 2007 | 01:14 PM
Drop Top 06's Avatar
Drop Top 06
If there's a problem with your sensors, your tuner should be able to pick up the code, and tell you if one of them is malfunctioning... I would return it to stock for the inspection.. It'll take 30-40 min to return to stock to pass.... Better than paying someone to find out what may not be wrong.
