Speaker Wire Diagram
How can I figure out what wires are positive or negative? And before you remind me about the search function; I tried & failed with that already. Thanks in advance!
Thanks. What I'm actually looking for is a diagram of the speaker wires inside the doors. I'm putting a tweeter where the 6 x 8 was and need to know which wire is positive and which is negative.
Also, I'm putting a 6.5" speaker where the sub was in the bottom of the door. I think the factory Sub was a 8ohm dual voice coil speaker and the one I'm putting in is a 4ohm single voice coil speaker. How do I wire this as well?
If your going off a Shaker HU the factory sub is less than 2 ohms!(it'sstamped or stickered on the speaker).If you're using the factory amps they may not put out much power to a 4ohm speaker.
ORIGINAL: drbobvs
Well, I ain't no electrician, so I don't know if this will give you what you need, but just in case........
Mike
http://www.2005stang.com/gallery/alb...81/radio~0.pdf
Mike
http://www.2005stang.com/gallery/alb...tc290b%26d.pdf
Front Left:
Positive: OG / LG
Negative: LB / WH
Front Right:
Positive: WH / LG
Negative: DG / OG
Rear Left:
Positive: GY / LB
Negative: TN / YE
Rear Right:
Positive: OG / RD
Negative: BN / PK
Why is that? The 4 wires that go to the sub really only carry the low signal ...
Front Left:
Positive: OG / LG
Negative: LB / WH
Front Right:
Positive: WH / LG
Negative: DG / OG
Rear Left:
Positive: GY / LB
Negative: TN / YE
Rear Right:
Positive: OG / RD
Negative: BN / PK
ORIGINAL: IA_Chiefs_fan
jwog666
Dec 27, 2021 08:09 PM
breaking
Oct 2, 2015 01:27 PM
