HELP.. gas tank FCKed up????
RE: HELP.. gas tank FCKed up????
No there is a TSB on this issue and you can live with it and do the 3 o'clock position or get the gas tank replaced and maybe the fuel pump and for most people it was problem solved.
I've only had one time the tank didn't fill all the way and it was just a little under (about 1.7 gallons) full. I think that was more how the pumps at that station were set than anything else. Every time I fill up it's close to what the computer says I've used, within .2 gallons.
Are you seeing the 1/2 tank indication after you're done or while you're filling up?
ORIGINAL: Jays Mustang
I push on the handle straight in and it works fine. I don't need to twist on anything, just pick up a little on the handleand straight in.
That's the way it works with mine too. Sometimes, I try to go to max click on the fuel start up, but it shut off. I have to put it on slow to fuel up.
I have an '07 and when it was new I had problems pumping gas a couple of times. But I haven't had any shut-offs since. Haven't a clue why though? [sm=dontgetit.gif]
But I'm happy with it. [sm=happy046.gif]
mrappe
09-26-2015 10:16 AM
