Trouble code... HELP?
Old May 14, 2007 | 06:54 PM
Intrcepter's Avatar
Intrcepter
Default Trouble code... HELP?
I keep getting a 0135 DTC.What does it mean?What would cause this? Is it serious?
thanks for any help you can give.
Old May 14, 2007 | 07:44 PM
Daniel60's Avatar
Daniel60
Default RE: Trouble code... HELP?
I have tried for 45 minutes to research this answer and this is the best I could come up with.
http://alflash.com.ua/MMC/MIdtc.pdf
Old May 14, 2007 | 08:32 PM
Lees07GT's Avatar
Lees07GT
According to my Diagnostic Code reference books, DTC P0135 is set when the PCU detects an out-of-tolerancecurrent in the exhaust manifold oxygen sensor (left or right bank, I'm not sure which). The oxygen sensors must be heated in order to accurately sense levels of oxygen in the exhaust. Power is supplied to the sensor's heater circuit and then is monitored for the proper current to insure the sensor's heateris functioning properly. Too little or too much current will set the DTC. IMO, the most likely cause of such a problem would bea blown fuse (if the heater circuit is fused), a wiring or connector problem, or a bad oxygen sensor, itself.
RedFire281's Avatar
RedFire281
0135 DTC = 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
Old May 30, 2007 | 06:32 PM
Linde's Avatar
Linde
ORIGINAL: Intrcepter
Did you worked this out?
I have same problem. Getting DTC 0133 0135 0153 155.
Have tryed everything.
Changed to new sensors, new extensions cables for front sensors(long tubes), turned of the rear sensors, new tune for my setup.
But everytime the codes come back.
As I can understand this codes often comes with the long tubes?
But now I am out of luck. Don´t now what to do.
I live in Sweden too, so there is not much help here in the country.
//Daniel
Old May 30, 2007 | 07:06 PM
RedFire281's Avatar
RedFire281
If you're running off-road pipes or long tubes you might need these:
http://www.steeda.com/products/steed...liminators.php
Old May 30, 2007 | 07:17 PM
Linde's Avatar
Linde
ORIGINAL: RedFire281
But If the rear o2 sensors is shut off in the tune you should not need them. As told by several tuners/people?!
// Daniel
Old May 30, 2007 | 08:14 PM
mx07gt's Avatar
mx07gt
+1 On this problem..
I am getting a slow responsive oxigen sensor...
This is getting annoying! someone help us
CS2007
Jun 25, 2019 09:45 PM
msavoia23
12
Jul 7, 2018 12:08 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
ChampInSD
Oct 2, 2015 04:55 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
