Tire Pressure Sensor error
Old May 22, 2007 | 12:00 AM
blaven's Avatar
blaven
Default Tire Pressure Sensor error
I was installing my offroad H today and took the battery off for easy access to the passenger side 02 sensor. Had it out for about 3 or 4 hours while i was working on my car. Got everything back together, battery installed, get in the car to fire it up and it said Tire Pressure Sensor Error on my cluster. I know i didn't hit anything at all when i jacked the car up. Threw in my xcal and went to read the codes and there weren't any being thrown. Anyone have any suggestions as to what is wrong? Thanks in advance.
Old May 22, 2007 | 11:16 AM
blaven's Avatar
blaven
Default RE: Tire Pressure Sensor error
bump, anyone have any suggestions?[]
Old May 22, 2007 | 06:07 PM
stangmann's Avatar
stangmann
same thing happen to me today because i disconnected the battery.
it appears this is normal when disconnecting the battery
the message center reads there is a fault in the tire pressure sensor monitor
the solution is to just drive the car because is uses a wireless signal from the tires and need to rotate to reset the message and you are correct there are no error codes when you read then with the xcal...good luck
Old May 22, 2007 | 06:11 PM
edified's Avatar
edified
+ 1 Stangman
[IMG]local://upfiles/37295/8D31E83119AC42C6BE818707AF937CF6.jpg[/IMG]
Old May 22, 2007 | 08:07 PM
blaven's Avatar
blaven
Yeah i posted that it went away in my H pipe thread when i went to start it up again this morning, weird stuff.
Jb145700
Aug 21, 2022 06:37 AM
SteelerNation82
Sep 16, 2015 07:11 AM
TfcCDR
Sep 14, 2015 12:08 PM
Sep 8, 2015 11:50 AM
zanemoseley
Sep 6, 2015 12:58 PM
