More panhard bar problems......
Old May 23, 2007 | 02:30 PM
tr6nut's Avatar
tr6nut
Default RE: More panhard bar problems......
ORIGINAL: ohnoesaz
ORIGINAL: ilmor
Can someone explain to me why the adj. panhard bar is good to have and specifically what does it do and how?
+86
When you lower the car, the axle will sometimes shift to one side of the car (rather than being centered). An adjustable panhard rod allows you to re-center the axle. Also aftermarket street panhard rods usually have polyurethane bushings, which are stiffer than the stock rubber bushings.
Old May 23, 2007 | 03:07 PM
ilmor's Avatar
ilmor
ORIGINAL: tr6nut
ORIGINAL: ohnoesaz
ORIGINAL: ilmor
+86
Do you know what issues may result from the axle moving to one side? I'm imagining, for example, tire's rubbing the fenders, axle hitting the exhaust, rear tires not following the front (i.e., trying to make the car turn), etc., etc. possibly even increased drivetrain fatigue.
Old May 23, 2007 | 04:01 PM
rmays06's Avatar
rmays06
ORIGINAL: ilmor
ORIGINAL: tr6nut
ORIGINAL: ohnoesaz
ORIGINAL: ilmor
+86
In sever instances yes it can cause rubbing and axle hitting the exhaust but most just get 1/4 to 3/8 inch shift which can cause tire wear and also not allow for as tight of turns and the correct center when cornering.
Old May 23, 2007 | 04:05 PM
Va. Stang's Avatar
Va. Stang
Hey Moosestang, I have the same set- upBMR ADJ and brace.And have had no problems. I will say that Ionly put about eighty ft lbs on the adj.pan hard bolts and about 40 ft lbson the brace.I have been a mechanic for thirty years (Industrial not auto) and felt it was to much for the bolts and sleeves. I used loctite on all nuts and have had no issues with them moving or looseness
flash_xx
Oct 16, 2015 07:23 AM
UrS4
Oct 3, 2015 06:23 AM
fastbackford351
Oct 1, 2015 12:24 PM
winner99
Oct 1, 2015 10:52 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
