Short Throw Shifter
Old May 23, 2007 | 10:47 PM
Joolander's Avatar
Joolander
Lord High Protector
Default RE: Short Throw Shifter
ORIGINAL: howarmat
You can go the cheap rout and get the saleen adapter....you just install that to the stock shifter and it convert your stock to a STS.
How does that work? And, is it any good?
Old May 23, 2007 | 10:49 PM
Bluestar's Avatar
Bluestar
+1
Old May 23, 2007 | 10:59 PM
howarmat's Avatar
howarmat
s197 Junkie
https://mustangforums.com/m_3079059/tm.htm
Its one of Tacobills writeups.....take a look through those because they answer many common questions on the board.
Old May 23, 2007 | 11:08 PM
Joolander's Avatar
Joolander
Lord High Protector
So it says the Saleen shortens by 25%. I know the Hurst does 40%. How much does the MGW shorten?
Old May 23, 2007 | 11:09 PM
lldsandsll's Avatar
lldsandsll
i'm looking at the saleen sts. they claim 26% reduction in shift distance. not bad for 45 bucks on ebay.
Old May 23, 2007 | 11:14 PM
07GTowner's Avatar
07GTowner
MGWcan be adjusted. It was anywhere from 50% to 20 or something like that. Depends on the number of turns you set it at, up to 12 turns max. Mine is 10 turns out. around 40-45% shorter and I love it.
Old May 23, 2007 | 11:28 PM
Joolander's Avatar
Joolander
Lord High Protector
So do STS'sacheive shorter action by making the arm shorter or what?
Old May 23, 2007 | 11:46 PM
redfireshaker06's Avatar
redfireshaker06
What do you guys think of the tri-ax? I pickedup a new onebut havent installed it yet.Itsanolder one so it still has there bushings. I can return it still if I want to.
Old May 24, 2007 | 12:29 AM
lldsandsll's Avatar
lldsandsll
tho its not adjustable, i dont see why it makes sense to spend more than what the saleen costs.
Old May 24, 2007 | 12:30 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
1+ mgw ALL THE WAY!!!!!!
ORIGINAL: mlcrycc
Which is best is strictly a matter of opinion. That being said, I love the new MGW shifter. Yes, you can maintain the factory boot and **** if so desired. I swapped out the shift **** over a year ago, but this pic is with the short throw installed.....
Mike
[IMG]local://upfiles/13557/CFBF455A87B241BEB84BDBCC89E3332E.jpg[/IMG]
